Getting conflicting information, please help...
Old 12-30-2008, 10:02 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
Get some break pad lube for the back of the pads and the pins, you'll never have a problem with squeaking.
Old 12-31-2008, 08:17 AM
tk353's Avatar
tk353
tk353 is offline
http://fatbillscustoms.com/
has step by step without removing the caliper
Old 12-31-2008, 09:23 AM
Beerninja's Avatar
Beerninja
Beerninja is offline
In the Fatbill directions he mentions that you need to torque the pins back down. Is that really necessary or just a good thing to do? Does anyone else torque their pins back down?
Old 12-31-2008, 04:39 PM
back again's Avatar
back again
back again is online now
Received 6,415 Likes on 2,590 Posts
What I do when I do them is pull the caliper off the bike and get the 9.00 rebuild kit. If you just push the pucks back in the bore your just pushing all that crud that's there you can't see without taking them apart.That crud will in time makes those pucks stick. Take real fine emory cloth and clean the pucks after cleaning them with solvent.It's your bike and you only have 2 wheels and brakes.You never know when you're gonna need to stop that thing.I like to get all I can out of things like brakes especially.I don't have bags on the Train so it usually only takes an hour and a half to do the job
Old 12-31-2008, 04:50 PM
sonar_chris
Its always a good idea to torque to spec. I personally don't (but should to do things the right way). One of the reason they use torque specs is to keep from damaging the bolt or the tapped hole that the bolt threads into.
Old 12-31-2008, 05:22 PM
tk353's Avatar
tk353
tk353 is offline
i cleaned mine with brake cleaner and a towel and no more crude. mine stay clean because i use the car wash to wash the bike.
http://www.cyclespot.com/lyndall_rac...es_install.htm
http://www.360brake.com/index.htm
Old 12-31-2008, 07:04 PM
conroskie's Avatar
conroskie
conroskie is offline
No you don't have to take the wheel off but I did notice that my front was wearing very unevenly. I pulled the caliper and made sure I had plenty of fluid in the mastercylinder and pumped out the pistons so that I could clean them real good with brake cleaner and a rag. Then I put my Lyndalls in. This solved my problem.
Old 01-01-2009, 05:43 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
+1 on cleaning the pucks before you push them back in. as far as torqueing the bolts, I don't but it is the feel thing, don't overtighten you will be sorry later. If unsure then yes torque them
Old 01-01-2009, 07:10 AM
raaaaaa's Avatar
raaaaaa
raaaaaa is offline
i have a 2001 fatboy and 50,000miles on it. I have replaced the rear brakes 3 times and I have never removed the rear tire just to replace the brake shoes
joe cosstello
05-23-2017 12:53 PM
BackRoader
06-11-2011 09:56 AM
sheetzakiss
01-22-2008 09:38 PM
DCS
12-10-2007 04:32 PM
Hdbiker1450
10-13-2006 08:55 PM
Quick Reply: Getting conflicting information, please help...
