Help! Brakelight/running light converter doesn't work right
Old 12-27-2008 | 03:12 PM
schumacher's Avatar
schumacher
Default Help! Brakelight/running light converter doesn't work right
I have the correct kit, but it only makes the right signal work correctly (as a running/brakelight).
The left doesn't work as a brake/running, but still works as a signal.
bulb is fine
Old 12-27-2008 | 06:38 PM
schumacher's Avatar
schumacher
no ideas?
Old 12-27-2008 | 06:51 PM
ngoti8tor's Avatar
ngoti8tor
Check the wiring in the connectors for the left signal light. Unplug the connectors and make sure everything looks good in them. It's possible one wire is not connecting.
If that's not the problem, it could be a defective module.
Old 12-27-2008 | 07:00 PM
tmitchellof PG's Avatar
tmitchellof PG
The converter is just a plug and play item, so it would be hard to guess what could be wrong. Did you disconnect the converter and go back to the stock setup, to see if everything works properly? The only other thing I would try would be to do a momentary disconnect of the bike's battery. This is like a reboot for the ECM, but I doubt if it has anything to do with the problem.
I guess it could be a bad wire in the converter.
Tom
Old 12-27-2008 | 07:23 PM
schumacher's Avatar
schumacher
I've switched it back a couple of times, and everything works fine in stock mode. Guess maybe it's a bad one.
Old 12-27-2008 | 11:09 PM
ngoti8tor's Avatar
ngoti8tor
It has nothing to do with the ECM. The electronics for the rear signal lights is inside the tail light.
If you've checked all the connections and all the pins are sticking as far out as they should be, then it must be a defective module.
Old 12-28-2008 | 12:46 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Take the module back, its gotta be bad. There's just not that much to the light circuit to go wrong, and if it operates normally when you put on the turn signal all of the wires and connectors are fine.
Old 12-28-2008 | 09:00 AM
tk353's Avatar
tk353
I would think either a bad module or the wrong one. I have heard if you have alarm strange things can happen
csaari77
04-17-2015 05:36 PM
volatile77
01-23-2013 04:40 PM
worthymccormick
01-26-2010 08:12 AM
worthymccormick
01-25-2010 04:32 PM
oldbie
Electrical/Lighting/Alarm
01-07-2009 07:10 PM
Quick Reply: Help! Brakelight/running light converter doesn't work right
