Changing pipes only,need to remap?
Old 12-26-2008 | 12:44 PM
57RebelRocker's Avatar
57RebelRocker
No need to on yours with just exhaust
Old 12-26-2008 | 01:39 PM
BluBob's Avatar
BluBob
Originally Posted by rottiepete
....change the pipes then get it dynoed....
For the price of that dyno run you can probably buy a pre-programmed PCIII from Jamie at FuelMoto. Then drop another $100 and you will have a complete stage 1. If you ever change parts down the road all you have to do is re-map (Fuel Moto, DynoMax, or another forum member can send you a map)
Old 12-26-2008 | 09:07 PM
rottiepete's Avatar
rottiepete
3rd Gear
Thumbs up Good thought
That's a good thought. If I've gotta fork out the dough for the dyno, for a few more why wouldn't I just put the PC in and dyno it too? Lots of great input guys.
Thanks again!
Pete
Old 12-26-2008 | 10:49 PM
Blk and Chrome's Avatar
Blk and Chrome
just pipes no need to remap, I will say wen you do remap em they run cooler and stronger
Old 12-27-2008 | 09:21 AM
tk353's Avatar
tk353
you will get many opinions. If you don't want the excessive heat and you want the engine to last then yes a fuel management and a dynotune or auto tuner.
Old 12-27-2008 | 10:42 AM
mojo55's Avatar
mojo55
Default remap
Just buy a pair of Xieds alot cheaper.
Old 12-27-2008 | 04:03 PM
tk353's Avatar
tk353
just buy a pair of 330ohm resistors, even cheaper
Old 12-27-2008 | 09:35 PM
rottiepete's Avatar
rottiepete
3rd Gear
Default re: Xieds
Ok.....I'll bite.....what I have read about the Xieds sounds like they may help, but they look like they can eat up the fuel mileage. I've also read that in the end I'd be better off doing the stage I download.
Old 12-27-2008 | 09:50 PM
tk353's Avatar
tk353
for less than a buck you can use 330 ohm resistors and make the stock ecm run in open loop all the time, just like it does when the engine is cold. If you dont want that then get a fuel management and a dyno tune or an auto tune ecm
if your 2006 does not have o2 sensors then i would say go with what the dealer says.
Old 12-30-2008 | 09:38 PM
rottiepete's Avatar
rottiepete
3rd Gear
Default Thanks all!
Here's what I'm gunna do.......I'm gunna bolt on the pipes.....run it and see how she runs.
Thanks everyone.
Pete
