Unusual Rocker Vibration
Old 12-17-2008, 01:29 PM
monster fxstc's Avatar
monster fxstc
monster fxstc is offline
Originally Posted by robzuc97
You had a problem before with them if I remember right? If the vibration disappears after you pull in the clutch (and therefore disengage the rear wheel drive) you can pretty much eliminate rear wheel balance or incorrect thrust. If they removed the engine, I would look at alignment. If the Rocker has a front motor mount at the tip that looks like a doughnut(not familiar with this model), look for the engine mount to be centered evenly on the rubber bushing. Check for any untorqued mounting bolts using final torque numbers below. The correct sequence for engine removal & replacement (if Rocker has same mounting hardware as a '06-07 FLHT) is: (1) transmission bolts to engine case finger tight, then 15 ft-lbs, then 30-35 ft-lbs. final torque {aligns transmission to engine} (2) the pivot shaft {goes through rear of transmission to align engine & trans with rear swingarm and requires special alignment tool if similar to FLHT with rubber bushings} to 90-110 ft-lbs (3) the front mount {sets engine and transmission aligned with swingarm to frame} 70-80 ft-lbs. (4) small bracket on right side of transmission to frame {locks all in} 30-35 ft-lbs 5) Upper bracket {between cylinders} head bolt support 28-35 ft-lbs, then the support assembly 45-50 ft-lbs {#4 & 5 lock all in & support upper engine movement}. Should get yourself a service manual (if don't have already) and you'll find alignment specifics for the Rocker in Chapter 2. Good luck, Rockin'!
Nothing like that, the Rocker has the B motor...solid mounted, not rubber mounted.
v-rodder
Softail Parts
07-31-2014 09:51 PM
v-rodder
Softail Parts
05-31-2014 07:07 AM
v-rodder
Softail Parts
05-09-2014 06:25 AM
v-rodder
Softail Parts
03-07-2014 07:59 AM
kmac22068
05-13-2011 06:57 AM
Quick Reply: Unusual Rocker Vibration
