wider front tire on night train?
Old 02-15-2010 | 08:35 AM
jefnightrain's Avatar
jefnightrain
Originally Posted by chopperness
anyone thought of trying a 21x3.0 on the front, think that will fit smoothly? CHeck out these......http://cgi.ebay.com/ebaymotors/21x3-...Q5fAccessories
That has been what I have thought about - DNA has a wheel that says it will fit the FXST/c & FXDWG - 21x3. I think they have the same front end as the FXSTB night train. I would really like to go to a 3" wheel if it will fit with my stock fender. I think the ride & looks will improve. KC International has either the 21x3 or 21x2.15 for $425
  #42
Old 02-19-2010 | 06:26 PM
vjsports's Avatar
vjsports
Default 150 tire on a 09 stock crossbone rim
  #43
Old 07-29-2013 | 07:02 AM
therickrob's Avatar
therickrob
Ok this is a great thread I really want a bigger front wheel ans tire.. my only question is spacer size for everyone that went with a 3.5 and does the stock rotor and brake have any clearance issues
  #44
Old 07-31-2013 | 10:23 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
You just need to make sure that if you need new spacers for a new wider wheel.
They put the rotor in the same position in relation to the fork leg & caliper as the stock wheel,
If that's done, it should work just fine.
I would be more worried about fender clearance.
The narrow fenders on bikes after 07 are closer to the tire than older ones and might not have enough room at the edges to clear a fatter tire.
Especially if the new wheel has to be moved a bit sidewise to get the rotor aligned properly.
In which case a new aftermarket fender might be needed as well.
  #45
Old 08-01-2013 | 10:30 AM
Echo6 Sierra's Avatar
Echo6 Sierra
Originally Posted by Tx_Outlaw
On the stock rim, I wouldn't go over a 90/90. The 120 is too wide for staying safe on the 2.15 rim. I'm running a 120 on a 3.5 rim on my '06 without issues. The 120 will not be covered by the stock fender and mods will need to done for it to even fit over the tire. I'm waiting for Metz to produce a 130 or 140 front tire. Either would be very cool!
That looks sick! I want to run a wider tire on my train. I have a JJ Doom rim up front but, I don't know how wide it is. The 21" came in 2.15 or 3 I think. I'd like to go with the 120/70 but I don't want to have to buy a new rim. I have a brand new 90/90 21 Dunlop that came with the bike but I'd much rather sell that and buy the Metz. I'm also running an aftermarket wrap fender and it looks like there's plenty of room in there for more rubber. My only concern is if the tire will fit the rim.
That's the best pic I have of the tire/rim up close...
  #46
Old 08-01-2013 | 01:32 PM
Ash16's Avatar
Ash16
That's a 120 on a 3.5" rim on Chuck's bike. I ran one too. Much better handling than the 90.
  #47
Old 07-06-2016 | 09:27 AM
Lowden's Avatar
Lowden
Stage I
Originally Posted by nightrider87
when i get new wheels for my night train, im getting a 21 x 3.5 front and im gonna use a 120 tire. i think it will fit but it will be really tight, i have a new front fender to go with it though
HI there, I need your help please.. What front fender did you buy to fit the Night Train? I have intentions of increasing to a 21 3.5.Any mods needed.. Regards
  #48
Old 04-17-2020 | 02:20 PM
Darryl Sampson's Avatar
Darryl Sampson
Stage I
Default What size is the rear tire and where did you get the rear fender
Attachment 541834
  1. what size is the rear tire and where did you get the rear fender?
Bucktown
09-25-2022 08:46 PM
joshag
02-19-2012 03:33 AM
Cav Cop
Wheels/Tires
06-19-2011 11:03 PM
jefnightrain
02-09-2010 08:21 AM
dietdewboy
08-14-2007 10:23 PM
Quick Reply: wider front tire on night train?
