What size spacer for DNA Mammoth rear wheel?
Old 09-25-2010, 05:30 PM
WARG's Avatar
WARG
WARG is offline
I used a 1/2" spacer. Has worked great.
Old 09-25-2010, 05:33 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
BLKnCHRME09Deluxe is offline
On my 09' i have a 1/2" installed. I have DNA wheels + pulley.
Old 03-16-2011, 08:53 AM
jcallesano's Avatar
jcallesano
jcallesano is offline
anyone know what spacer ill need for a 2006 night train?
200 mm rear tire. 3/4"axle
Old 03-16-2011, 09:56 AM
Rick101285's Avatar
Rick101285
Rick101285 is offline
for the 06 train you need a 1/2" pulley spacer and a 1/2" axle spacer
Old 04-17-2011, 11:07 AM
looneytune's Avatar
looneytune
looneytune is offline
Anybody know what pulley spacer I need for a 2005 Deuce with 18 x 5.5 wheel and 180 tire? Is there a best or easiest way to measure for the correct pully spacer? Also, what is the closest I can run the belt to the sidewall of the tire? I'm going from the stock 160 tire to a 180, is it ok to to run the same spacer on both combos or should I add an extra 1/8th" to what I already might need for pully spacing to compensate for the 180 tire. I see Vulcan sells a 1/8th spacer for a 180 Deuce conversion. My concern is I get the pully to far out and then I can't get the rotor to line up correctly. If anyone has installed DNA wheels on a Deuce, what axle spacers did you use for both wheels? I know lots of questions, but I'm stuck right now. Thanks for any help.
mikeskustoms
2018+ Softail Models
02-01-2019 07:49 AM
beary
Wheels/Tires
01-01-2015 09:07 AM
Tahitijah
10-21-2012 11:58 AM
kyleplusitunes
08-29-2011 09:34 PM
Quick Reply: What size spacer for DNA Mammoth rear wheel?
