Luggage rack...heritage classic
Old 04-03-2006, 10:00 PM
06Heritage's Avatar
06Heritage
06Heritage is offline
Default Luggage rack...heritage classic
I picked up a luggage rack for my heritage, and the instructions say to remove the screws from the sissy bar. it looks like i wont be able to get to the bottom two, without taking off the whole rail. for anybody thats done this, is it a pain in the *** ? or does it just look that way ?
Thanks
Old 04-03-2006, 10:04 PM
Doc's Avatar
Doc
Doc is offline
Default RE: Luggage rack...heritage classic
I have been there and done that. You have to take it all apart. Not hard, just take your time.
Old 04-04-2006, 12:19 AM
Keystone's Avatar
Keystone
Keystone is offline
I just did mine today. You need to remove the rear two from each side of the bracket. You can then loosen the front one and swing the entire assembly forward. That way you can get at the four Torex screws that hold the sissy bar in place. Hope your screws come out easier than mine! I had to extract five of the six Torex screws/bolts from mine. Could not get then to loosen with out stripping the heads. Guess it was a combo of the lock tight they use and the soft metal.
Old 04-04-2006, 07:05 PM
Mike05's Avatar
Mike05
Mike05 is offline
I did mine with out any trouble. It just takes some time. Be sure to protect the rear fender when wrenching around. You could easily let somethng slip and cause a boo-boo (I did it on my tank...just a small ding...but it is a ding)
Old 04-04-2006, 07:42 PM
2004 heritage's Avatar
2004 heritage
2004 heritage is offline
5th Gear
which luggage rack did you go with ? i am in the market myself
Old 04-05-2006, 09:36 AM
IndyHSC's Avatar
IndyHSC
IndyHSC is offline
What the heck, as long as you have it apart, you might as well spend a couple hundred more and go for the quick disconnect side plates and docking hardware
John
Old 04-05-2006, 11:17 AM
fatheadonsoftail's Avatar
fatheadonsoftail
fatheadonsoftail is offline
Details, part Numbers?
Old 04-05-2006, 08:44 PM
slack's Avatar
slack
slack is offline
Yea I had to take it all apart like the others said it is not hard just take you time and you'll be fine. I thought about getting the quick disconnect, but my wife was already mad (I just spent $300 in stuff that week) so I thought I would wait. I used a little thread lock so the screws didn't back out. good luck.
Old 04-05-2006, 10:48 PM
RockyTopRider's Avatar
RockyTopRider
RockyTopRider is offline
As IndyHSC said I would go ahead and get the quick detach. I ended up doing mine twice after I purchased the quick detach. It ain't hard, but takes some time.
Old 04-05-2006, 11:36 PM
wilcox's Avatar
wilcox
wilcox is offline
Anyone tried this fold down luggage rack from Kurakyn http://www.kuryakyn.com/products.asp?bn=harley&ci=2655
[IMG][/IMG]
Quick Reply: Luggage rack...heritage classic
