Sissy Bar install - idiot (newbie) proof?
I know this will seem like a super lame question, but i'm a totally cycle n00b.
I'm getting my bike in a couple of weeks and I just want to make sure that the sissy bar plates and bar itself just bolt on. I mean, I dont have to remove any tail lights or anything like that? I'm not getting a detachable, just a standard mid-low for my fatboy. The sales guy is trying to talk me into letting the service dept install it and I figured I could just bolt it on myself.
Thanks for answers to a rediculously lame question I'm sure.
mmmm have not yet done it myself, but one thing I would like to point out though is that if you are looking at getting a detachable sissybar for your fatboy, you will need a detachable sissybar as well as the docking kit for it. you will need to install a docking kit on the rear fender struts first that will be able to receive the detachable sissybar.
a bolt on sissybar is a just bolt on job, a detachable needs a few parts more.
in neither case do i think that you need to remove tail lights or such. But then again i have not actually done it myself yet.
Most bolt on modifications you can do yourself. Just make sure you have a good set of tools and a lot of patience. Work slowly, follow directions and if possible, get a service manual. Some of the instructions that come with the kits aren't complete and reference the service manual.
For tools, I'd suggest you get a set of torx and allen head sockets that will fit your ratchet and if you don't have one, get a knuckle joint for your socket set.
If you get stumped, post a question on here. A lot of the folks here have been at the same place.
Good idea about the heat gun.....The lock tite that the factory uses can be a Bi***. Use a layer or 2 of painters tape above and below the fender strut to help prevent damage for when the torx socket slips (ask me how I know).
In my case, there was so much lock-tite I had a difficult time putting the new bolts back in when I installed the detachable hardware. Had to chase it out w/ a tap.
Have fun w/ your new toy!
Don
Don
If you're installing a rigid mount sissy bar, then you shouldn't have too much trouble. Just a couple of bolts and it's done. If you're installing a detachable sissy bar, then chances are that you'll have to have the directional relocation kit which changes the way the rear turn signals are mounted. The directional relocation kit can be a bit of a PITA to get installed if you don't know what you're doing, and the directions from HD SUCK A$$!
