Kuryakyn grips to big!!??
RE: Kuryakyn grips to big!!??
Has anyone ever tried to use the grip-kits golf pros use to put grips onto clubs. Sometimes they double or triple wrap the tape around the shaft to accomodate a larger grip. A little solvent to temporarily wet the tape and allow the grip to slide on. After the solvent dries -- about 12 hours -- the grips should be on tight. Not so tight, however, that they would have to be dynamited off if you ever decide to change grips. I'm not sure what the solvent might do to the chrome, however.
Just a thought.
Just a thought.
I just put the kury flame grips on my train 2 weeks ago,,,glued the left side and left set overnight and didnt use anything on the throttle side and I have had no problems at all,,,been thru the twisties already and had it up to 115 with a pretty good grip on them and never a slip!!!
ORIGINAL: Softtail Bob
The right side is not glued on at all because it has to spin for the throttle. It locks in place under the controls so the only way it should come off is if the control wa to come off. Now I've never put on any after market grips so there may be a chance that the Kuryakyn grips mount differently so if this is the case someone else chime in.
I put the ISO grips on my heritage last year. I haven't had a problem with them at all. they are great grips and would recomend them to anyone. I used the glue that came with the kit and followed the instructions. The right side goes on just like the stock Harley grips.
