Oh PS, I replace my front running/turn lights a lot
Who said you need a shaft drive for low maintenance?
I don't change oil on my belt and I changed the oil on my fjr shaft every 6000, haven't adjusted it either! woo hoo!!!
yea i have done that once in the first year already...and once i changed out my tail light, changed the bulb within a month of putting a new red one in it.
BTW that small allen plug at the bottom of the engine should not be disturbed: it is there as a leftover from the machining process of the crankcase. If you strip that out=$$$ to fix. I recommend the HD SM for any work.
+1...that plug is LocTite'd at the factory for a reason...it's not meant to come out...don't ask me how I know this...
