New way to get even more room with your floorboards (kind of long)
Well some of you may have read about my floorboard modification with the HD extended rider floorboards ( P/N 50409-04) and the Harley Goodies extensions. Well my mom gave me her old Mustang seat with riders back rest (she did the springer seat that all the deluxe riders are doing) and I put it on, only problem, it pushed me forward and the extended rider floorboards were a little to close for my liking. So after doing some research I found that Cycle Visions (Local to San Diego thank god) had a floorboard kit called the "Go-Forward" floorboard extension kit that moved the floorboards, shifter arms, kick stand, rear break pedal all 2 inches forward ( http://www.cyclevisions.com/cv-acces...ard-extensions) They also give military discount by the way. So I decided since I'm going to use the Mustang seat, I would try to use the HD Extended rider floorboard pans with the Cycle visions kit and see if it worked. Well it worked out GREAT! I have now successfully move my floorboards 4" forward for a total of 200 bucks, while retaining a stock look. Seems to me that's about as cheap as you can get for that much movement. So here are a few pics.
Just the HD extended rider boards
![](http://i35.photobucket.com/albums/d177/sonar_chris/Picture170.jpg)
Cycle visions kit and extended rider boards.
![](http://i35.photobucket.com/albums/d177/sonar_chris/IMG00016.jpg)
![](http://i35.photobucket.com/albums/d177/sonar_chris/Picture138.jpg)
Cycle visions kit and HD extended rider boards
![](http://i35.photobucket.com/albums/d177/sonar_chris/IMG00017.jpg)
![](http://i35.photobucket.com/albums/d177/sonar_chris/Picture171.jpg)
![](http://i35.photobucket.com/albums/d177/sonar_chris/IMG00018.jpg)
The install was strait forward and pretty easy, the only things to look out for are the kick stand spring, its a real pain in the *** to get back on, and the rear break line, you will either need a new line, or bend the old one (which is what I did) Install took me about an hour and a half, and now I will never have to worry about leg room ever again. I wasn't sure if the Cycle Visions kit would work with the extended rider floorboards, I was afraid they would hit the front fender, but its all good. So if you need more room than stock go with the extended rider floorboard pans, if you need even more spend the $119.00 on the Cycle Visions kit and you will be one happy person.
If anyone has any questions just let me know and I will do my best to answer them.
If your bike is a softail, you can use a standard forward relocation kit, whether pegs or boards. I did it with my Deuce. I changed from pegs to boards as moco sits the pegs too high. Stock boards on the fwd kit are heaven. It provides me a wide range of leg movent.
John
John
https://www.phatperformanceparts.com...43460&CartID=1
This kit. Says 00- 05 so maybe later softies have a changed frame. The 06's went with the standard/stock Deuce frame so they could do the wide tire.
Thanks for the link and another option sherman1125, but that kit is $179.00 and the Cycle Visions kit is only $120.00 (plus they sell a 2" extender that allowed me to keep my buck shot shifter linkage). I would rather bend the break line then pay 60 bucks for a new one.
Taken from website:
"Go-Forward" Floorboard Extensions
This "Go-Forward" moves your floorboards and pedal assembly 2" forward for a more comfortabole feel. Will not work with engine guards on FLSTS or FLSTC Heritage or Springer. Extension plates are made of...."
Man Chris!... You got me all excited until I read the "not for Springers" part... : (
Why is that? Can anyone explain to me what is different about the flooboard part of a Softail frame when it has a Springer front end on it? Is it a neck angle thing, or is it saying it will not work on a Springer with engine guards?...(confused)
@6'9" I need every inch I can get!
