"DYNO" Numbers For SOFTAILS
Old 03-21-2014, 09:39 PM
CagelessRoy's Avatar
CagelessRoy
CagelessRoy is offline
2013 FLSTC Heritage Softail
103" stock engine, stock exhaust, Outlaw 587 Air Cleaner w/ breather bolts
5300 miles
Dynojet
CF: SAE Smoothing 5
Run Type: RO
Run Conditions: 70.17F, 29.23 in-Hg, Humidity 22%, SAE: 1.00
4th gear pull
Max Power = 60.89 (5100 rpm) Max Torque = 75.53 (3000 rpm)
  #972
Old 03-25-2014, 06:16 PM
oct1949's Avatar
oct1949
oct1949 is offline
Originally Posted by Prw3
stock 103 usually makes 75hp to 78hp right out of the box, good pipe, air cleaner and a stage 1 efi upgrade usually produces 14-18 additional HP at best.
I'd think, 14-18 gains with just stg1 would be the exception and not the norm.
I've seen many stg1 well tuned 96'''ers that if they get 10 more Hp and Tq they are doing pretty good..
  #973
Old 03-25-2014, 06:42 PM
Prw3's Avatar
Prw3
Prw3 is offline
Originally Posted by oct1949
thats just not true... The only way you'll get those #'s is with cams and stg1...
I have to call bs on your claims...----
i seen hundreds and hundreds of dyno sheets,, and only the bs tuners that do std dyno's and a tweaked sheet can get 14-18 additional tq and hp on only a stg1 tune...
lololololol
  #974
Old 03-26-2014, 10:18 AM
DigbyHD's Avatar
DigbyHD
DigbyHD is offline
Thats just not true... the only way you'll get those #'s is with Cams and stg1...
I have to Call BS on your claims...----
I seen Hundreds and Hundreds of Dyno sheets,, and ONLY the BS tuners that do STD dyno's and a tweaked sheet can get 14-18 additional TQ and HP on only a stg1 tune...
I got a stage one, pro pipe, se tuner and heavy breather and made 15-20 hp and torque over stock.
Was there when they dynoed it.... well the last 2 hrs
  #975
Old 03-26-2014, 03:54 PM
DigbyHD's Avatar
DigbyHD
DigbyHD is offline
finally got around to posting my graph. Sorry about the crappy pic but let me know what you think
  #976
Old 03-30-2014, 11:56 AM
kblhd's Avatar
kblhd
kblhd is offline
Default ported heads
What can I realistically expect if I have my heads ported. Currently have:
82 HP
99 torque
  #977
Old 03-31-2014, 08:47 PM
imrotton2's Avatar
imrotton2
imrotton2 is offline
82 HP
99 torque
i dont think you will gain over a couple in each... your pipes are killing the power... im getting 97 hp and 108 tq out of my 98 model s&s 96"... im running a 2/1 header.... jmo
  #978
Old 04-08-2014, 09:28 PM
BabyBooey's Avatar
BabyBooey
BabyBooey is offline
Stage III
Default 2014 Breakout no.s
Just got tune done today. D&D Lowcat exhaust with SE billet intake and HD Super tuner. 71/76 HP, 86/93 torque.
  #979
Old 04-08-2014, 09:59 PM
madjeeper's Avatar
madjeeper
madjeeper is offline
WOW, how much for 5 HP? You need a cam now.
  #980
Old 04-09-2014, 10:39 AM
DigbyHD's Avatar
DigbyHD
DigbyHD is offline
Could anyone take a quick look at my graph for me, only thing i see is the HP and Tq dont cross over at the perfect RPM but is close
thanks
Quick Reply: "DYNO" Numbers For SOFTAILS
