"DYNO" Numbers For SOFTAILS
Old 02-26-2009, 07:55 AM
oct1949's Avatar
oct1949
oct1949 is offline
Originally Posted by Scooter1001
This is interesting stuff!
My numbers:
'06 Heritage
PCIII
V&H HS Pro 2 into 1 pipes
K&N airbox
Wood's TW-6 geardrive cams
84 hp, 84 tq
Yep.. thats way I started it, Not to take credit for the idea because as I stated the baggers have had theirs going for several yrs and I got the idea for this thread from theirs.
At least its good to know that some SOFTAIL owners are enjoying it and participating by posting there information and dyno numbers here...
  #82
Old 02-26-2009, 08:21 AM
oct1949's Avatar
oct1949
oct1949 is offline
If I can figure out how to I will post the dnyo sheet, that way it will show if it was a
SAE or STD as some want to know which one was done
also most sheets have all the motor work listed on bottom.
  #83
Old 02-28-2009, 03:14 PM
SUUIE's Avatar
SUUIE
SUUIE is offline
I f...ing lost power and now have brown mufflers as well! See sig for specs.
Stock - 66.27hp & 78.52tq
Stage 1 - 65.63hp & 75.22tq
Opinions on the loss of power? I'm thinking that it's the quiet baffles.
Suggestions on removing the browning?
Charts here: https://www.hdforums.com/forum/4642873-post14.html
AFR here: https://www.hdforums.com/forum/4654277-post49.html
AFR: https://www.hdforums.com/forum/4659383-post57.html
  #84
Old 03-01-2009, 11:03 AM
xbonz's Avatar
xbonz
xbonz is offline
2008 Xbones
Hooker Trouble Makers, SERT, SE Air kit
81.63 HP/91.08 TQ
I never saw baseline numbers prior to the bike going into the shop, anyone have those #'s?
  #85
Old 03-01-2009, 11:36 AM
tony2772's Avatar
tony2772
tony2772 is offline
Originally Posted by xbonz
2008 Xbones
81.63 HP/91.08 TQ
check the begining of this thread, numbers should be close to the same.
  #86
Old 03-02-2009, 05:11 PM
Called2Duty's Avatar
Called2Duty
Called2Duty is offline
Default heres mine
I also have a 4 degree advance to hit the SE 204 cams power band a little earlier, also knocked down the rev limit200 rpm to save those $ parts
Attached Thumbnails "DYNO" Numbers For SOFTAILS-dsc00181.jpg   "DYNO" Numbers For SOFTAILS-dsc00222.jpg
  #87
Old 03-02-2009, 05:38 PM
Called2Duty
Might as well put this in Its from my last bike. The work was done at 3.5 k miles and it felt stronger that when brand new...
It has both the base run and after dyno tune
2007 FXSTD with SE 204 Cams- W 4 degree advance
Big Radius Pipes
SE Race Tuner
SE/ k&n filter
  #88
Old 03-02-2009, 05:50 PM
oct1949's Avatar
oct1949
oct1949 is offline
Default finally got my print out photod
Here is my sheets with STOCK #'s,---then STAGE 1+ CAMS VS STOCK,----after Andrews 26h cams.
1st thunbnail is copy of base run
2nd thumbnail is after Stage1 and Andrews 26's I drew in red line to compare because they were done at two different dealers and could not get it on one sheet.
3rd Andrews 26h cams installed. 3-18-09.
Follow up::
Decided to go Andrews 26h, & stay with the Rush slip ons, I like the sound. Looked at D&D but have never heard in person, and BSL's, lose a little TQ down low.
200+ miles & I am pleased with the 26's, they produce good #'s for my riding style, 2200-4000 rpm's (90% of the time two up).
Still over 80#'s TQ at 5.2k rpm's, alot better than the 63#'s the stock motor made.
Over 83#'s of TQ from 2200-5000 rpm's.
Increased 15-20 % TQ and HP over stock engine #'s across the board.
The engine runs better and freer now, 6th doesn't feel like its laboring at 60mph and pulls it easy even two up.
Others say the 26's are done between 4- 4.5k rpm's, the (dyno shows its strong 2-5k rpm's)
For Stage1 and Bolt in Cams there just enough for now and I am satisfied with them.
Ride safe...
UPDATE at 2600 miles since 26h's install.
I'am totally pleased with the cams. the power increase across the board is great.
Where I used to ride mostly at 50-55mph in 5th gear because 6th was laboring to much at anything under 65. I can now ride in 6th at 58+mph easy, we ride mostly two up. Plus she now pulls better at 60mph in 6th than she used to at 50mph in 5th for passing.
As a added bonus the mileage used to be best riding at 50-55mph in 5th (41mpg), if I used 6th it would drop below 40mpg.
Now using 6th gear and running 58-70 on the last 10 tanks I have averaged 43+mpg, and thats even riding 50% in town and 50% County and State roads.
Thats at least 2mpg better and a good deal of more power..
  #89
Old 03-14-2009, 09:17 AM
tiiiim2's Avatar
tiiiim2
tiiiim2 is offline
Default my 103
deweys heads woods 6hg cam hpi 51mm intake sert tuner 3.37 gearing
Attached Thumbnails "DYNO" Numbers For SOFTAILS-copy-of-x2giifch1vwgm4wedqb.jpg
  #90
Old 03-14-2009, 01:02 PM
Renegade1's Avatar
Renegade1
Renegade1 is offline
Just picked it up from the tuner.
Quick Reply: "DYNO" Numbers For SOFTAILS
