Here is mine. 2006 Fatboy with 88, Stage 1, V&H BSS, with SERT.
good numbers but get that thing on the dyno! you are running way to lean at idle and way to rich where you are crusing. you will probably be able to get more power out of the bike to if you get it tuned.
My 03 Heritage FLSTCI Was Maped When I Got It With V&H Big Shots Staggered.
Since Then I Put In 21869 - Quiet Baffle .
Question Is Do I Have To Re map It ????
Thank You
here's the dyno from my 03 night train.
95" s and s 585 cams and gear drive cam kit. se flat top pistons, se pushrods, se air cleaner and back plate, sert. as far as heads they have bigger springs anf and a 5 way job, but no real head work yet.
95" using SE 10.25 dome pistons
SE211 cams
Head work
PC3
SE open intake
SE2 slip-ons w/BCT baffles
99 HP and 96.5 lbs. torque at 5500 rpm. Wish the rev. limiter had been set to 6200 cause the hp was still going up and the tq had just started to go down.
