"DYNO" Numbers For SOFTAILS
Old 08-22-2012, 02:03 PM
2003Custom1200's Avatar
2003Custom1200
2003Custom1200 is offline
Here I post again.
2007 Softail Deuce 96"
V&H Big Shots Staggered.
Arlen Ness Big Sucker 2
Woods tw-555 cams
fuel moto push rods
93 hp/ 97 ft lbs.
Did have a pull of 95hp/100 ft lbs. But a/f was off and figured better save some mpg. also got the tq curve to flatten out at 3200 instead of dropping down
Before the cams I was at 79hp/90 ft lbs
  #722
Old 08-22-2012, 03:50 PM
I Corps's Avatar
I Corps
I Corps is offline
Here is my Dyno sheet. The H-D dealer did not give me a before/after. Can anyone comment on if this is good or bad for a 2012 Heritage Softtail Classic with Stage 1, hi-flo AC, Super Tuner and Cobra slip-ons?
  #723
Old 08-22-2012, 04:29 PM
pkvir's Avatar
pkvir
pkvir is offline
Wonder why the dyno started at 3000rpm, I usually shift at 3200. I would like to see what the torque is at a lower rpm. For example, my torque peaked at 3250rpm. As far as peak hp/tq, it's about the same as my 2012 with stage 1, my peak torque was 100ft lbs
  #724
Old 09-05-2012, 12:39 PM
RICHIEMACK's Avatar
RICHIEMACK
RICHIEMACK is offline
Default new tune
2006 night train 95 big bore 48mm throtle body 37 g andrews can se cam plate bassani 2 into i.se air cleaner....95.3 hp 100.1 tq..SERT..STD...DONE AT HARRY;S MACHINED PARTS,BY RICK STETSON
  #725
Old 09-05-2012, 06:48 PM
TheTroupe's Avatar
TheTroupe
TheTroupe is offline
Harry's Machine great guys that have been around a long time.
And great numbers.
  #726
Old 09-12-2012, 05:08 PM
JayOhh's Avatar
JayOhh
JayOhh is offline
Maybe the wrong place to post this. But I'm amazed by some of the cam-change numbers in here.
I live in Norway, so a big bore with cams and all the other stuff will cost me around $6000. Which I think is alot!
So to the guys with just exhaust, AC and cams. How much did the power actually improve on the road. Is it like night and day, or are the numbers on the dyno.sheet the biggest difference?
  #727
Old 09-12-2012, 05:54 PM
TheTroupe's Avatar
TheTroupe
I have an 88 ci 2003 Heritage.
2 into 1 pipes, SE AC with a K&N Filter, Power Commander III - this was very good
Then I added SE-204 cams and had it dyno tuned.
Yes it is like night and day.
  #728
Old 09-20-2012, 09:58 PM
montrealbob's Avatar
montrealbob
montrealbob is offline
Default 2007 softail custom
Here are my numbers after my 103 build.
Sorry, my file is too big, i need to resize my file before i download it here.
Im at 105 lbs of torque at 4000 rpm.
  #729
Old 09-21-2012, 01:17 PM
ghoticov's Avatar
ghoticov
ghoticov is offline
I honestly could care less what my numbers say on a dyno sheet, that's why I have never had mine dyno'd.
I bought my bike basically stock. Added a PCIII, V&H BSS, Big Sucker and Wood 555 Cams and wow, it was a huge difference. I don't know what my numbers are (I assume about 90HP and 100 TQ) but the butt feel is huge. It woke the bike up...if you are thinking about doing cams, do it... you won't regret it.
  #730
Old 09-21-2012, 07:08 PM
TheTroupe's Avatar
TheTroupe
Your setup would improve with a good dyno tune. You do not need to look at the number if that is your choice, but you *** will fell the difference.
I know, I've felt it.
Quick Reply: "DYNO" Numbers For SOFTAILS
