"DYNO" Numbers For SOFTAILS
#61
Also, what's kinda funny to me is that there are websites (Harley dealers) that say that the 96ci motors generally get between 89 and 92 ft. lbs. of torque (no HP, though). Is this an advertising glitch? Maybe a little white lie? I wonder because I read some folks on this thread are getting less than advertised after their stage 1 upgrade or other mods. What's the deal with that?
#62
2009 Softail Custom Stock Dyno Results.
One thing I hadn't seen on here is anyone post results of a stock bike.
Before I made any changes to my bike, I wanted to see what I was starting with. As proven again and again, you can't really go off of what the dealer tells you.
Run Conditions: 23.88 Deg Celcius Humidity 32% SAE: 1.11
Max Power = 61.68
Max Torque = 79.26
I now have a SE Heavy Breather Intake and am considering the new power commander for the 2009 series softail. For the EFI unit, I was wavering between: PCIII, SERT, and the Thunder-MAX Auto Tune. The PCIII is the cheapest option, so I don't mind starting there.
Thanks to all that have posted so far.
Todd
2009 FXSTC
Max Power = 61.68
Max Torque = 79.26
Todd
2009 FXSTC
#63
Max Power = 61.68
Max Torque = 79.26
Todd
2009 FXSTC
Max Power = 61.68
Max Torque = 79.26
Todd
2009 FXSTC
If you go back to the (1st) post on this thread I stated what my stock and after tune numbers were.
Good point about the dealer #'s on stock output, as the numbers Harely puts out are aggressively higher than most real world #'s
I wonder if their test numbers come from the CRANK instead of the rear wheel.
#64
#65
04 fatboy stock 88 b engine , stock cam, stage 1 = v+h short shots, se (k+n) air filter , thunderslide carb kit. 63hp and 79tq. Now 95" big bore at 97hp and 110tq with V+H PRO-PIPE
#66
#67
Dont remember stock figures, but first kit was a 103 kit, put down 101Hp 104 lb fts,
My latest edition 117" stroker motor, currently running vance and hines staggerds, and I am swapping them out for the 2 into 1 boarzilla this winter should help TQ numbers.
current numbers 131hp 140 TQ
It sure surprises alot of people, I love it..
#68
#69
Got my bike back from the dyno and it come up with some impressive results.
Run conditions 37.9 Deg Celsius, 991.04 mbar, Humidity 6%, SAE 1.03.
Max Power = 87.24 Max Torque = 91.88
88B Fatboy 2006 , V&H BBS exhaust , Big Sucker Air Cleaner, Power commander 111 USB, Custom Map, SE204 cams and minor head work.
Was also told if the temperatures were cooler I would of been looking over the 90hp so I am happy .....
#70
Well I think I win the gold for the lowest numbers. I never checked stock but my 06 88B makes 64.92hp and 72.41tq. I have Sampson True Duals with fishtails, Arlen Ness Big Sucker Airfilter, and a Screaming Eagle tuner. I was told that it was the fishtails that are killing my performance and i would probably gain about 8 hp and 10 ft/lbs if I changed to normal mufflers, but i like my fishtails...I plan on doing a cam at some point and may bite the bullet and change the mufflers at that point.
