"DYNO" Numbers For SOFTAILS
#431
#432
PRE 74.7 HP @ 4700 RPM
91 TQ @ 3270 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
POST 93.1 HP @ 5095 RPM
109.1 TQ @ 3657 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
103 SE Stage 3 KIT
SE259E Cams
Manual Comp Releases
91 TQ @ 3270 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
109.1 TQ @ 3657 RPM
09 FLSTF
V&H BR
SE Heavy Breather
SE Race Tuner
103 SE Stage 3 KIT
SE259E Cams
#434
#437
#438
2006 FLSTFSE2 Autumn Haze
124 R&R Motor w/Billet round port heads w/comp release
Horsepower Inc. 58mm Throttlebody
Speed's High Velocity Air Cleaner
Static Compression Ratio 10.8:1
S&S Crankshaft
Camshaft S&S 640
S&S Roller Rocker arms
SERT
Rivera pro clutch
8mm hypo wires
R&B Racing LSR 2-1 Pro Stock 124 2" primaries C style 17" collector
Brembo 4 pad calipers front and rear w/12.6" front rotor, 11.5" rear
Baker Builders Kit.
S&S Crankshaft
Camshaft S&S 640
SERT
Rivera pro clutch
8mm hypo wires
Baker Builders Kit.
#439
S&S Crankshaft
Camshaft S&S 640
SERT
Rivera pro clutch
8mm hypo wires
Baker Builders Kit.
S&S Crankshaft
Camshaft S&S 640
SERT
Rivera pro clutch
8mm hypo wires
Baker Builders Kit.
