"DYNO" Numbers For SOFTAILS
Old 12-17-2020, 04:53 PM
cdonis's Avatar
cdonis
cdonis is offline
Default 124 Breakout
Riding the gold country, in california.
124 / 640 Cams/ D&D bobcat / 138.99 HP / 140.7 TQ
Tuned by Dean Hodel RE Engineering
The following 3 users liked this post by cdonis:
98hotrodfatboy (11-22-2022), Deluxe2012 (09-04-2021), Michael Rogers (10-10-2021)
  #1442
Old 12-17-2020, 05:34 PM
Alexandre Presbiteris's Avatar
Alexandre Presbiteris is offline
6th Gear
Originally Posted by db133
Hi
Whats is the MPG ?
kind regards to all
Miles per gallon
  #1443
Old 12-18-2020, 12:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,422 Likes on 3,622 Posts
Looks great.. sure it's a blast...
  #1444
Old 12-19-2020, 12:45 PM
cdonis's Avatar
cdonis
cdonis is offline
It sure feels a lot smoother . It was lean down low so I feel good that it’s safe, smooth, and picked up a bit of tq/hp. I haven’t been around the forum lately , hopefully you are doing well.🤝
  #1445
Old 12-19-2020, 01:23 PM
98hotrodfatboy
Yeah I noticed... Thanks all is good... Have great Christmas..
cdonis (12-19-2020)
  #1446
Old 06-02-2021, 10:06 PM
Hawaiianchef's Avatar
Hawaiianchef
Hawaiianchef is offline
5th Gear
97 FXSTC
Mikuni 42mm Carb
Hooker Header- tuned flow Exhaust 2 into 1
Crane HI-4E Ignition,coil and wires
Header tuned to midway between HP and torque
Head and cam work with Dyno run
on 10/02 Dyno'd at 78.5 HP and 83 ft-lbs torque
sinct Dyno 5/08 Complete top end overhaul Cylinders bored .010 over with new pistons, cam,roller rockers, valves and springs
  #1447
Old 06-25-2021, 12:51 PM
Mac24's Avatar
Mac24
Mac24 is offline
6th Gear
2007 FXSTD Duece
96ci fuel inj. - 6 speed
Screamin Eagle SE 204 cam
LSR 2-1 pipes
Tuner
31T front pulley / 68T rear pulley
Dyno tuned 90 hp / 104 torque
  #1448
Old 06-27-2021, 07:45 AM
samsquanch's Avatar
samsquanch
samsquanch is offline
2003 fatboy. 98" carillo 10:1 pistons, andrews 37 cams, tc96 heads, ported intake myself, white brothers e series pipe, k&n intake, downloaded a tune for my pc3 that looked like randok numbers jumbled together, sent it to "stay tuned" Don Morris, he broughtbit up from 95hp and 102ftlbs to 104/115. 21t front procket soon to be switched back to a 25.
Less is more when doing a backyard port job. Very easy to make your bike run worse then it did before you began. And there is no going back.
  #1449
Old 06-27-2021, 08:57 AM
98hotrodfatboy
Originally Posted by Hawaiianchef
97 FXSTC
Mikuni 42mm Carb
Curious to which Cam and what type of head work, do you have a dyno sheet on that that you can post?
  #1450
Old 06-30-2021, 05:25 PM
swavet22's Avatar
swavet22
swavet22 is offline
Stage I
Originally Posted by oct1949
Any one have the dyno numbers of their bike with V&H big shot longs????...
I also have the V&H intake.
Quick Reply: "DYNO" Numbers For SOFTAILS
