"DYNO" Numbers For SOFTAILS
Old 05-19-2015, 09:15 AM
dirtyike's Avatar
dirtyike
dirtyike is offline
2014 CVO Deluxe. V&H Big shots and SE Race Tuner
95.52 HP
104.98 Torque
  #1132
Old 05-20-2015, 06:09 AM
cossack OZ's Avatar
cossack OZ
cossack OZ is offline
Smile CVO '08 Springer Dyno Results
96.49
113.52
SE heavy Breather
V&H Big Shots ( baffled )
  #1133
Old 05-23-2015, 10:46 AM
Fiveinch's Avatar
Fiveinch
Fiveinch is offline
6th Gear
Default Intro and Sheet
I was diggin this post and thought I'd share my numbers from a pre-break-in dyno run/tune on a 2015 Breakout with SE 4 kit, Heavy Breather, and V&H 2 into 1.
Elevation: 5300ft
Rounded: 108hp/106ft lbs max
  #1134
Old 05-23-2015, 12:56 PM
cdonis's Avatar
cdonis
cdonis is offline
What cams do you have? That's with the higher compression ratio and se heads?
  #1135
Old 05-23-2015, 07:07 PM
Fiveinch's Avatar
Fiveinch
Fiveinch is offline
6th Gear
SE-259E cams, 10.5:1 compression.
  #1136
Old 05-24-2015, 09:02 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
You guys do realize that a full pass on the dyn o before a break in pretty much make the break in pointless don't you?
brock1 (04-27-2016)
  #1137
Old 05-24-2015, 10:17 PM
cdonis's Avatar
cdonis
cdonis is offline
10 4 tuner, I found that a little odd. No way I'd let them ring it out without seating the rings.
  #1138
Old 05-25-2015, 12:59 PM
Fiveinch's Avatar
Fiveinch
Fiveinch is offline
6th Gear
The dyno/break-in argument is noted, but I take into account that materials today are not materials (lubricants, metals, compounds) of yesterday (yesteryear?). Even with the early dyno run, good break-in practices are still a good thing. I won't really wring the ol' girl out til the Doc (the shop Tuner) gives his okay (beyond what he's already given me).
  #1139
Old 05-25-2015, 02:00 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,422 Likes on 3,622 Posts
To all that are curious, A dyno break in is a great way to seat the rings. It's a better controlled environment....Heat up/cool down.. several times on the dyno is the way to go...
  #1140
Old 05-26-2015, 03:26 PM
harleytuner
I'm not trying to turn this into a discussion on the proper way to break an engine in. I'm just saying that if they ran it to 6200 they might as well full tune it. Me personally, After I do a build I do 5 heat cycles, then it goes on the dyno for a quick tune up to 4000 RPM's, then it goes to the customer for some miles then back for a full tune. Other shops do it different and that's fine. My way has worked great for me over the years so I don't plan on changing now, regardless of what new materials are being used. If it aint broke, don't fix it.
Quick Reply: "DYNO" Numbers For SOFTAILS
