Rear turn signal options?
Old 09-30-2008, 07:25 PM
eddieflyer's Avatar
eddieflyer
eddieflyer is offline
+1 on the kuryaken tail light. Love it
Old 09-30-2008, 07:40 PM
travis dasher's Avatar
travis dasher
travis dasher is offline
Originally Posted by Cheesecake
Here are the Auto gems on the back of my XB... not a great picture, they are black and cover up the holes nicely... when I get the time.... and get done with a few other mods I'll post some better pictures
CC
I like the Auto Gems on your Bones. I was looking at the website and saw the wiring diagram for the baby bullets they have 3 wires ground, run, directional. On the rear there are only 2 wires on the stock setup. I have the run-turn-brake module already, so will I just connect the ground wire and the directional wire? Any advice you can give would be appreciated.
Old 08-30-2011, 06:42 AM
reefonline's Avatar
reefonline
reefonline is offline
Default run brake turn lights all in 1
i put on kellermann 100 micro df on my bones, turn run brake lights all in 1...
only problem is they are a little too long and since i slammed the bones 2" they keep scraping when i turn.
would anyone know if there is an alternative to this lights? im looking for something maybe mini bullets with all brake turn and running lights in one...
Old 08-30-2011, 06:47 AM
Miked053's Avatar
Miked053
Miked053 is offline
I got the easy brackets laydown license plate and turn signal relocate and that worked out very well for me.
Old 08-30-2011, 07:19 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
I don't think you're going to find a 3-in-1 solution for anything much smaller than 2 inches, bro. I was running 1.25" mini-bullets previously, but had to revert back to my 2" stock bullet housings (rear only) for the 3-in-1 dynamic LED clusters I just installed. Couldn't find anything much smaller that was a full 3-in-1 cluster.
Old 08-30-2011, 09:23 AM
shooker's Avatar
shooker
shooker is offline
I run the alloyarts they cover the end of the struts for a clean look
Old 08-30-2011, 01:35 PM
sp9997's Avatar
sp9997
sp9997 is offline
All the options are so far expensive. My 08 fatboy came with the sissybar and backrest and I wanted to put saddlebags and at the same time wanted the ability to take the sissybar off whenever I want to go solo seat... I looked the DIY Cheap mods .. and came across the best thing ever...
https://www.hdforums.com/forum/4258138-post103.html
The good thing about this is that even when I install the ezbrackets they do not stick out too much ...in fact it does not stick out at all.. when I want to take out everything it takes me literally under a min... ofcourse I had to change the strut bolts to HEX instead of the Star that comes from maco..
Hopefully this helps you ...
Old 08-30-2011, 02:47 PM
TW's Avatar
TW
TW is offline
I usually get rid of the turn signals for the cleaner look.
Hand signals are legal here in Illinois.
Old 08-30-2011, 04:22 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is online now
Received 20,248 Likes on 5,858 Posts
The "all in one" tail lights are not legal in many states because turn signals are too close together....I bought mirrors that have them in the glass...this solves that problem. Very visible..my bike passes inspection and you cannot see them when they are off.
Old 09-01-2011, 11:10 AM
reefonline's Avatar
reefonline
found the heartland ones which are a little over priced (in my opinion) and im not sure if they have a combination of red leds for run/brake and amber for turn... that would be GREAT!
Quick Reply: Rear turn signal options?
