Rocker C~owboy
#43
#45
Jerry
#47
7 is the older of the two, and the one I used for this.
There really isn't a huge amount of difference between the two that makes one worth several hundred dollars more to me.
I was just lucky, and friend gave me both programs including correl draw 11, which I use for my vinyl cutter to make sticker and shirts with.
The beauty of having at least two different editing programs, is one will have features the other doesn't and so forth, so with that being said, you can switch back and forth from one to the other to get even better details.
My friend that gave me the programs taught me most of the programs' abilities, and I learned, and am still learning to fully utilize them. I am still no where close to being expert with this stuff.
Its not hard to learn, but you still have to have an eye for it, other wise one just can't advance.
#50
I would suspect any high end airbrush artist could muster it up for you. I don't look for it to be cheap though. I have an airbrush setup however, and I plan to do it on my own. Unless I can figure out how to get it screen printed on the tank like they apply the decals from the harley custom shop. Its a process I am not to familiar with, but it would yield the best results, and I am sure I can figure out where or how to get it done.
