Periodic engine light and red Key light on FB
Sorry for my ignorance, but what do you mean by stator? I'm new to Harley's...
Welcome to the forum from Texas.
Sorry for the cliche but Google is your friend.
https://www.google.com/webhp?sourcei...0d01clr%20code
https://www.google.com/webhp?sourcei...orcycle+stator
Hi, I was reading this thread about diagnostic codes and how to determine theIr meaning. I tried it on my 2002 Heritage softail classic, but the coffee that came up was different. It read "d01clr". Any suggestions on how to find out why my engine light came on? Or what that code means?
I would say run a voltage check at the battery with the engine at 2500 rpm. You should get around 14.2-14.6 volts, if I remember correctly. You can do it, but if the failure is intermitting like mine was, you may not see anything.
