softail hot seat
I would be interested in this topic. We all agree that seat would get hot if you have to go through stop and go trafffic. What I am wondering is if there are heat shield that can be made under the seat. I also think that wider front seat may help. But, I can not try wider seat as I am not that tall only 5'8". I know alot of heat shield from car is made of aluminum or carbon fiber.... Carbon fiber may be an answer.. searching google...
As I recall, that was one of the knocks on gel inserts - they tend to feel hot, especially in the warmer climates. While the engine temperature plays a significant part, and reducing your engine temps will certainly reduce any perceived heat, I do believe the gel inserts in and of themselves are inherantly problematic from that perspective.
Roger
Roger
I would say tunaman is right, its your gel pad in the seat. they get hot and can actually burn you, from what guys on here say. I did touch a seat this summer in the sun with a gel pad and it was super hot. I would think you could pull the cover and replace the gel pad with some memory foam. I have also read a sheepskin cover works, as said before, too.
Try a Kuryakyn saddle shield.
See link
http://www.kuryakyn.com/products.asp?bn=Harley&ci=3613
Regards
See link
Regards
