banjo leaking
Old 07-28-2008 | 12:43 PM
TX REB's Avatar
TX REB
Default RE: banjo leaking
Try a teflon gasket or a o-ring. CrimsonThunder&nbsp\\;were talking about banjo bolts not guitars.
Old 07-28-2008 | 12:55 PM
CrimsonThunder's Avatar
CrimsonThunder
LOL!&nbsp\\; Oh, really?&nbsp\\; Not Guitars?&nbsp\\;
Old 07-28-2008 | 01:34 PM
sportncruise's Avatar
sportncruise
ORIGINAL: *PIGPEN*
Yeah its leaking&nbsp\\;\\\\\\;between Banjo bolt head and breather manifold.
Wow, I read it but went right over my head. Teflon won't help this. Try to find a gasket.
Old 07-28-2008 | 01:35 PM
sportncruise
Posting sucks. might need to just find a flat rubber for anything and just cut something out.
Old 07-28-2008 | 01:54 PM
*PIGPEN*'s Avatar
*PIGPEN*
Iam just going to take the kit off clean the oil off and reinstall with the locktite on the threads. If it still leaks ill try a gasket.
Old 07-28-2008 | 01:56 PM
*PIGPEN*'s Avatar
*PIGPEN*
Just ignore them. every forum has them
ORIGINAL: TX REB
&nbsp\\;\\\\\\;CrimsonThunder&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;were talking about banjo bolts not guitars.
Old 07-28-2008 | 02:44 PM
sportncruise
ORIGINAL: *PIGPEN*
Lock tite won't help as it isn't leaking at that end, my fault.
Old 07-28-2008 | 02:45 PM
sportncruise
Get a gasket like an exterior outlet gasket. Cut a hole the size of the bolt then trim to the size of the head.
Old 07-28-2008 | 03:13 PM
*PIGPEN*'s Avatar
*PIGPEN*
I found some gasket material here and many different hole punches. Ill just make me some gasket washers for the banjo bolt.
Old 07-28-2008 | 03:15 PM
PoorBoy's Avatar
PoorBoy
Too much oil in the tank will cause eventual seepage out the banjo.
Quick Reply: banjo leaking
