That \\;\\\\\\;is the older years kit. I put it on my 2008 deluxe. There shouldnt be a problem with this kit on my bike \\;\\\\\\;right? Everything fit just right except for the leak \\;\\\\\\;I will check my stock parts when i get home later.  \\;\\\\\\;\\\\\\\\\\\\\\;thanks for the help.
Had the same problem with an SE. Went to the Ness Big Sucker which eliminates those fittings. I'm real happy with it.
I guess this is the problem. I just went and took the bolts out of my Big Sucker and on the front there are rubber inserts on the adapter plate. No leaks!
Yeah its leaking \\;\\\\\\;\\\\\\\\\\\\\\;between Banjo bolt head and breather manifold.
Threads are letting it leak. Strange, mine has nothing in this area and doesn't leak. Try anything to seal the threads, loc tite might do it. Teflon around the threads might do it also.
