pipe discoloration
pipe discoloration
i just installed v&\\;h short shots along with xied"s. my old pipes were blue as hell but the new ones have turned a goldish yellow right at the head. what if anything does the discoloration mean? i left the stock ac. in the future i will install stage 1 and fuel pak. thanks.
RE: pipe discoloration
I remember reading once in Cycle magazine that you could spray white grease in the pipes before installing them and they wouldn't blue or discolor. And to remove any fingerprints and grease off the finish before firing up the bike. Never tried it though so don't know if it actually works or not.
Big Al
Big Al
ORIGINAL: thundergod
what is the cause and what does blue or yellow mean. it does not bother me just curious. thanks
Don't think the white grease would have helped in this instance.
Big Al
ORIGINAL: souljah
Ok here is the deal \\;\\\\\\; fuel x air produce \\;\\\\\\; burn rate as your pipes are diametrically opposed flow rates \\;\\\\\\; which will produce colouring as temperature builds \\;\\\\\\; outside atmospheric pressure will determine cooling of metal
The color \\;depends on how hot they get.
And how fast they cool down.
New pipes - spray the inside with heat paint, coat as much as you can get at from the head end, it really works. I did my Shovel 5 yrs ago and there is barely any color and I do alot of in town stop and go's. Years ago they had some compound called "Blue-away" that you polished on and it took the color off.
bad, davidson, discolor, discoloration, discolored, front, fuelair, grease, harley, mixture, motorcycle, pipe, pipes, remove, yellow
