cyclesmiths apehangers
RE: cyclesmiths apehangers
ORIGINAL: RoninRI
dont know about the cyclesmiths but i do have the 16 inch wild 1 chubbys the quality was great , but i dont think they offer theirs with the intregral risers . Iwould check their website they have customers bike pix
Yes Wild One does offer that style. However I would not personally go that route and here is why, You only have one option of an angle for the bar's. You can not roll them forward or pull them back or put them where you want them, you are stuck with what ever position they come in. Something to think about also is if you do it, and you go with 16"ers or taller you need (well should) replace your stock riser bushing's with the stiffer poly bushing's. I have only had 16's or taller so I am not sure if you should do the bushing's with a shorter bar, you might want to "just because", you know what I mean?
KB
ORIGINAL: RoninRI
good point about the bars with built in risers, that would be a pain with no adjustment, do you have poly bushings installed, does it eliminate all play in the riser clamp?
KB
