Is oil temp 260f too hot?
Old 07-04-2008 | 10:36 PM
128auto's Avatar
128auto
Default Is oil temp 260f too hot?
Just installed a dip stick temp gauge, stuck in the traffic for 10 mins this afternoon, outside temperature 80f, traffic wasn't completely stopped but moving slowly, temperature hits 260f, motor oil starts breaking down at around 260f makes me worry. I don't need an oil change yet, I use Amsoil on my Sportster, it seems to run a bit cooler. I know this big twin runs hotter, is it a bit hot for weather like today? I am just curious.
Old 07-04-2008 | 10:46 PM
tk353's Avatar
tk353
Default RE: Is oil temp 260f too hot?
My 07 runs 200 to 220 when it is 99 outside after doing the stage one and dyno tune. I use Amsoil also
Old 07-04-2008 | 10:47 PM
lh4x4's Avatar
lh4x4
No.
Old 07-04-2008 | 10:58 PM
128auto's Avatar
128auto
I think your PCIII forces the bike to run opened loop, that's why it runs richer and cooler, Amsoil helps too.
ORIGINAL: tk353
Old 07-04-2008 | 11:04 PM
WARG's Avatar
WARG
My 06 Fatty runs between 210 and 220 usually.&nbsp\\; In temps above 90 I've seen it hit 230.&nbsp\\; I use amsoil and have a dyno tuned PCIII which I am sure helps.&nbsp\\;
Old 07-04-2008 | 11:13 PM
cspcrx's Avatar
cspcrx
mine ran that hot. I installed the IEDs and had synthetic installed at my 1k yesterday. Im in phoenix it was 112 out side. So you can only imagine how hot the asphalt is.&nbsp\\; On the ride home at speeds between 40-45 sitting at lights my guage was 230. I must say these IEDs and now the synthetic are helping a lot.
Old 07-04-2008 | 11:47 PM
breaknbad's Avatar
breaknbad
The hottest i got my 04 deuce was 230.
&nbsp\\;\\\\\\;
You could feel the heat coming off of it.
&nbsp\\;\\\\\\;
Maybe your new gauge is wrong.I have&nbsp\\;seen quality gauges be wrong from the factory.&nbsp\\;\\\\\\;That seems awfully hot. Engine managment should of helped with the heat better that that.
&nbsp\\;\\\\\\;
If gauge is right&nbsp\\;\\\\\\;I would change oil soon. That seems pretty hot to me.
&nbsp\\;\\\\\\;
David
Old 07-05-2008 | 01:04 AM
128auto's Avatar
128auto
May I ask what is IEDs
Call me a fool
Old 07-05-2008 | 01:09 AM
Other Sheep's Avatar
Other Sheep
IED. Inline enrichment device. Made for the 07 and 08 bikes with O2 exhaust sensors. They simply plug into the O2 lines and fake the ecm into changing the air/fuel mix to a richer setting. Easy $70 fix for the lean condition of the new bikes. Nightrider.com has them. It is a pretty cool website for the Harley.
Old 07-05-2008 | 01:13 AM
128auto's Avatar
128auto
What about my 06 model?
Quick Reply: Is oil temp 260f too hot?
