what full pipes will fit on the rocker w/o any mods?
RE: what full pipes will fit on the rocker w/o any mods?
I read something about a BR not fitting. \\; V&\\;H says they will not either. \\; I say something on here that says to use GIB'S bracket. \\; Who is this guy and what is the bracket? \\; Are they for sale somewhere?
Tim
Tim
I'm Gib.....
The bracket is something I designed after seeing how poorly the pipes fit my bike with the included bracket. \\; Mine moves the pipes farther inboard to eliminate the binding created between the heads and frame when using the Vance &\\; Hines supplied bracket. \\; It also makes sure that the upper and lower pipes are parallel from the side and top. \\; If you need one, just shoot me an email.
As far as what pipes actually fit.....So far, the only thing that fits without alignment issues is the Big Radius 2 into 1 pipe. \\; The Short Shots Staggered will fit, like the Big Radius, but there are alignment issues as well, and I'm currently working on a bracket for those.
Rocketman69
12-03-2023 01:03 PM
