Ping or tick while accelerating
 \\;\\\\\\;\\\\\\\\\\\\\\;I have a 2008 softail deluxe with stage 1 filter,Vance and Hines duals exhaust, and Vance and Hines fuelpak running 91 octane gas.When i get on the throttle to pass a car or feeding onto a highway in 5th or 6th gear ,it starts to ping or tick. The temperture here in south texas is pretty hot.Probably 100 degrees on each day. Does anyone know how to fix this problem.
RE: Ping or tick while accelerating
ORIGINAL: TX REB
 \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;I have a 2008 softail deluxe with stage 1 filter,Vance and Hines duals exhaust, and Vance and Hines fuelpak running 91 octane gas.When i get on the throttle to pass a car or feeding onto a highway in 5th or 6th gear ,it starts to ping or tick. The temperture here in south texas is pretty hot.Probably 100 degrees on each day. Does anyone know how to fix this problem.
I found some 93 octane here in Illinois the other day. If you can find it, it may be worth a try.
MikeM
+1
ORIGINAL: chazzy
YOu could be lugging the motor \\;\\\\\\;when hammering the throttle in that high a gear. \\;\\\\\\; I'd say if you are doing 55mph in 5th or 6th gear, drop down to 4th....that way you are sure not to lug the motor. \\;\\\\\\; These motors don't like to lug.
