shudder at take off
RE: shudder at take off
If you are doing everything right, like enough throttle, it sounds like a clutch adjustment. I'm no expert, but I'd be surprised if you have a hydraulic clutch on your bike. But, HD may have put them on the CVO's.
Your oil capacity is probably around 3-1/2 quarts but when you change the oil and filter, only add 3 quarts, let the bike warm up, then set the bike on the side stand and check the oil adding as necessary. If you put 3-1/2 quarts in the tank, you'll overfill the bike because there is always oil left in the crankcase.
ORIGINAL: wooosaa
no dumping..just letting it pull...,maybe giving it a little juice....I ave a hydraulic clutch..does that matter? Sorry this is my first Harley....pretty sure there is no cable....
Thanks
Thanks
