Passing lamps not working
I have an 06 Heritage Classic and the passing lamps are not working.
The switch on the forks is turned on.
I have not checked the fuse yet but are there other electrical components on the same circuit that would not be working also if the fuse was blown?
Any other ideason whatit might be?
Thanks
Thanks
RE: Passing lamps not working
Also check the plug ins to the toggle switch. It has been very dusty in our area and mine had some dirt inside the plugs ins. I blew them out and also cleaned them. Mine are now working and back to normal. Also the plug ins may have come unplugged. Should be an easy check for you.
same problem.the sealed beams are sourced from asia and are crappy quality.after many warranty claimsI eventually replaced the entire unit with ones that were not sealed so i could replace the crappy bulbs with decent ones - haven;t had a fail for quite a while. I was fortunate that my dealer swapped them under warranty.
ORIGINAL: ggreenetx
