Hand grip install
Old 05-04-2008 | 10:54 AM
davered51's Avatar
davered51
Default Hand grip install
Putting new handgrips on a 07 Heritage. Is it really necessary to use adhesive on the left grip? Kit claimed to include some but didn't. They have the notch and go under the switch housing to avoid slippage. And if I do use adhesive, what can I use?
Thanks
Old 05-04-2008 | 11:00 AM
bcox's Avatar
bcox
Default RE: Hand grip install
I didn't use any on mine and it has never moved. Some say hairspray works good.
Old 05-04-2008 | 11:23 AM
tk353's Avatar
tk353
did you look inside the grip?
Old 05-04-2008 | 12:05 PM
Loser1's Avatar
Loser1
I just installed new bars on my bike yesterday. The left grip was held on by the left control housing. The grip itself has a couple of alignment tabs that fit into the housing so it doesn't move. The service manual does state to use a grip adhesive but it seemed none was used from the factory.
HTH,
L1
Old 05-04-2008 | 01:01 PM
gunner065's Avatar
gunner065
I do believe that HD grips have the recess to prevent the grip from coming off. Most after market ones don't. When I put mine on (Kuryakyn), I tried hair spray but it didn't work. The ISO grips came with glue but I didn't want the hassle if I wanted to change them out at a later date. I put a couple raps of duck tape around the bar and it works best kind.
Old 05-04-2008 | 02:14 PM
davered51's Avatar
davered51
Thanks, these are Harley replacement grips so I'll go with no adhesive.
Old 05-04-2008 | 02:45 PM
captbobrcc's Avatar
captbobrcc
just put a set on my deluxe and went with some clear silacone adheasive, twisted that mother on there,tightened the screwes and it is solid as a rock---good luck with it---Cap
Old 05-05-2008 | 10:18 AM
WAhog's Avatar
WAhog
Harley are always plugging 'glueless' design. I recently added a set and the old ones (flame) didnt have any adhesive and the new ones did not require an either. Check the HD catalogue it should mention if they are glueless but check the instructions I'd hate to think of it coming off if we're wrong!
Old 05-05-2008 | 02:33 PM
mke125125's Avatar
mke125125
go to sports authority or wal-mart and get some grip tape for golf clubs. put it on your bar and spray some wd40 into the new grip so it will slide easily over the tape. the wd40 will disapate quickly and your grip isnt gonna move.
Old 05-05-2008 | 02:49 PM
hardhead's Avatar
hardhead
i used krazy glue for my ISO grips on my stock heritage bars.it doesn't budge a bit.now i want apehangers and i may have to use a blow torch or a hand grenade to get the grip off!
