Timer Cover on 2008 Deluxe
I'm doing some massive upgrades - 08 Deluxe - at the dealer right now.. they asked if I wanted to replace the timer cover ?
Since much of the engine is chrome and I'm chroming the inner primary -along w/ all chrome hardware.. I guess they figured they ask..
However I thought that the Timer Cover was already chrome ? I gave them the go-ahead.. but since the bike is not here .. I thought I would put it out here for a quick answer...
Is it polished aluminum ?
RE: Timer Cover on 2008 Deluxe
Pearl Black / Pearl White 2 Tone 2008 Deluxe..
Front - End already Chromed.. w/ Mustang Solo Seat
Currently at the Dealer having the following Done...
Hoping to get it back this week.. and will post pictures...
ENGINE BUILD
HeadQuarters 103 Kit w/ the 575 CAM 10.5:1 Compression
SERT Tuned
Heads and Jugs Diamond Cut out of Las Vegas
D&D Fat Cat
Variable Pressure Clutch
Arlen Ness Stage II Big Sucker
Alren Ness Smooth 8" Air Filter Cover
WHEELS / ROTORS / SWINGARM / BRAKES
Fat Daddy 50 Spoke Wheels - Removing Front Hub Cap
Chrome Front Wheel Spacer Kit Harley 41583-07
Chrome Rear Wheel Spacer kit Harley 41221-08
Chrome-Plated Brass Valve Stem Caps - Acorn Nut Harley 41148-98
Chrome Lower Belt Guard 60654-07
Chrome Swing Arm 48607-08
Classic Chrome Rear Axle Nut Cover Kit 43132-08
Chrome Rear Axle Adjuster Hardware 41202-08
Chrome Socket Head Cap Screw Hardware Kit for Rear Belt Sprocket 43245-07
Chrome Brake Disk Hardware - Front 46646-05
Chrome Brake Disk Hardware Rear 46647-05
American Wire Wheel Radial Rotors
Performance Machine Domino Pulley
Harley Chrome Pulley Mounting Hardware - Hex
Performance Machine 6 Piston Front Brake Chrome - Lyndall Z Brake Pads
Harley Rear Chrome Brake and Bracket - No PM Chrome Calipers available for 2008 Rear as of yet.
FLOORBOARDS and FOOT CONTROLS
Extended Reach Rider Footboard Kit Kit pans 50409-04
Nostalgic Footboard Insert 50187-96
Chrome Rider Footboard Brackets 33698-07
Harley Goodies - Floor Board Extenders
EZ-Brake
EZ-Shifter
EZ- Rear Shifter Eliminator
CHROME ENGINE
Polished Stainless Steel Gear Shift Linkage - Slotted with Bar & Shield Logo 33760-98A
Chrome Rear Master Cylinder Kit 41777-05A
Chrome Front Fender Hardware Kit 94415-05
EFI Intake Manifold Cover Harley 27483-07A
Classic Chrome Headbolt Cover Harley 43822-01
Chrome Billet Aluminum Lifter Covers Harley 18088-02
Chrome Box Bolt Covers Harley 43868-99
Cylinder Base Cover Harley 32042-07
Chrome Oil Filter Cover Kit Harley 62448-01
Braided Stainless Steel Fuel Crossover Line Harley 63692-00A
Fuel Tank Fitting Cover Harley 62809-06
Chrome Voltage Regulator Harley 74610-08
Chrome Inner Primary Cover Harley 60792-06B
Chrome Timer Cover Screw Kit Harley 32690-99A
Chrome Front Fuel Tank Mounting Hardware Kit 62965-01
Chrome Hardware Kit - Primary Cover Harley 60801-06
Chrome Hardware Kit - Cam Cover Harley 94058-03
Chrome Hardware Kit - Transmission Harley 34856-06A
PASSENGER FOOTBOARDS
Chrome Softail® Passenger Footboard Kit Harley 52715-04
Nostalgic Passenger Footboard Insert Kit Harley 50190-96
DASH
Chrome Flush-Mount Fuel Cap and Gauge Kit Harley 62818-08
Chrome Console Kit for Softail® Models Harley 71202-03
Guage Visor Ring Harley 74661-04
Wind Shield
Harley Low Profile Smoked Detachable
FUTURES / Final
Burly Bikini Bars
Radical Rearview Mirrors
Chrome Hand Controls
Diamond Cables
Nacelle
ENGINE BUILD
SERT Tuned
D&D Fat Cat
EZ-Brake
EZ-Shifter
CHROME ENGINE
DASH
Wind Shield
FUTURES / Final
Burly Bikini Bars
Diamond Cables
Nacelle
