Changing my Air cover
I have done a SEARCH, but couldnt find anything so can someone help me as I have had 2 different answers from 2 different HD shops here in Sweden,
I am changing the Football Air cover with just the round cover plate so the air filter isnt covered , If I do this do I need to re tune the bike ? I have a 2006 FB.Do I need to do anything or just bolt it on ??
Thanks
Thanks
RE: Changing my Air cover
ORIGINAL: Rick_M
Thanks
Thanks
Have you already put on a stage 1? cuz if you have already put on a stage 1 and ur just going to replace the cover then no, you don't need to tune again.
If you have not put on a stage 1 then yes, you will need to tune it by removing the cover and box behind the cover.
You will need to change the whole air filter set up first if you want to run an uncovered filter. Something like the Screaming Eagle, Arlen Ness Big Sucker or K & N will be needed to put a round cover on.
Stage1 download is all you will need to stop the bike running too lean.
You will be suprised though of the improvement it does make to the running of the bike.
ORIGINAL: skulznflames
Best bet is to do exactly what skulznflames said then either get the stage 1 download or put in some form of fuel management system to keep the engine, and your thighsfrom frying.
