Fatboy Headlight question
RE: Fatboy Headlight question
ORIGINAL: fbhawg
part number 67907-96B. $130 in catalog, watch E-Bay and they go for about $60. If you have the fancy nachelle the part number is different. Go up one wattage on bulbs and the difference is unbelievable. You are right about the weak flashlight they come with, I never felt safe. I'm still not a fan of night riding but this is the best add on I've put on.
My 03was a sealed beam, did they switch later in the year? FLSTF, I knew somebody would ask that and I can't for the life of me remember. I'll look either tonight or tomorrow after work. Sorry I didn't see this sooner. It's a cheap upgrade and man does it make a difference. There's no way I can run highs all the time like I did before. I've been flashed on a split highway!
I think in 03 all softails came with a H4 Bulb and housing except for the Fatboy which had a sealed beam. I am guessing Harley had to get rid of their backstock so switched on all of the other models and kept the sealed beam on their top seller.
I wish I saw the headlight Anubiss is talking about it is cheaper than the one I bought. Also check the delta headlight JCWhitney has listed in the Motorcycle headlights listing.
The change out is definitely worth it.
FLSTF, sorry for the delay. The Eagles Club got between work and home last night. I went up to an H9, 65 watt and a H11,55 watt on the low beam. The H11 says H11 LL, not sure what the LL means. It's probably not as bright as some of the light bars with HID lighting but it's light years ahead of any sealed beam I've seen. The light that comes on these things is just plain dangerous. I did the Silverstar and some other kind someone suggested and it was a waste of money. For $120-$130, or about $60 on E-Bay its great. Harley has a HID for about$500 bucks also but I'm not in the income class to afford that.I can't believe JC Whitney has anything for $16 that can be worth anything. Good Luck
