Forward Floorboard Extensions for 2007 Deluxe
Old 04-07-2008 | 11:22 PM
aviator's Avatar
aviator
Default RE: Forward Floorboard Extensions for 2007 Deluxe
my bad.... the extended floorpans only moved 1 1/4 inch further forward, not the 1 1/2 inch I said before. the E-Z brake lever moved the pad about 3/4 inch forward, and down about 2 inches. the extended shift lever moved the shifter pad forward 1 3/4 inch.
Old 04-08-2008 | 05:53 AM
indigoblue2001's Avatar
indigoblue2001
Thanks Coaster!
Old 04-08-2008 | 05:56 AM
indigoblue2001
Thanks Aviator!
Old 04-08-2008 | 06:07 AM
indigoblue2001
Thanks All!!
I had both the new Traditional pans/Floorboards (HD # 50187-96, 34627-99, 44248-96, and Harley Goodies floorboard extensions added to my bike yesterday at the Stealer. They look Great. HG Extensions work like a charm, now all I have to do is install HD part # 50409-04 to move the floorboards forward an inch.
Next project, purchase and install Samsons True-Dual Longtails in Mini-Cholo with HD Stage One air-cleaner and tie it together with a "way over priced" HD race tuner so I don't run lean.
The Stealer told me that the above mentioned pipes, air-cleaner, race tuner and labor woul dbe around $1700.00 bucks.....Say freggin what?
Old 04-08-2008 | 08:43 AM
aviator's Avatar
aviator
I don't have a clue what the cost is for the exhaust you want, but, for about $400 you can order a power commander or similar fuel management system and HD SE or Arlen Ness A/C and install them yourself. if you can follow instructions and do the floorpans, then you can do this. another option is to find an independent mechanic - they usually charge a lot less for laborthan a dealer.
post some pictures - let us see your handiwork!
Old 04-09-2008 | 07:19 AM
indigoblue2001
Thanks for the info.................Do you know if the HD PN 50409-04 Extended Reach Foorboard Kit will work with the already installed Harley Goodies floorboard extensions that move the floorboards out from the bike?
Old 04-09-2008 | 09:29 PM
sonar_chris's Avatar
sonar_chris
ORIGINAL: indigoblue2001
Yes they will. I have had both on my bike for quite some time.
Chris
Old 04-10-2008 | 07:28 PM
indigoblue2001
Thanks Chris.....When you added the HD part moving the floorboards forward, did it require moving any of your foot controls forward too?
Old 04-10-2008 | 09:57 PM
sonar_chris
I still have the stock length shifter arms and there is no problem with that. The brake lever is the HD extended one though. I didnt like how the stock pedel felt with the stock floorboards so I changed it out long before the extentions. I would recomend the extended break pedel though but the shifter arms will be just fine.
Chris
Old 04-11-2008 | 07:13 AM
indigoblue2001
Thanks for the tip Chris!!
