Stage 1 and Remap
RE: Stage 1 and Remap
Springer,
I have the Stage I on my bike, and the wife's 2001 Heritage also, and did them myself, except for the re-map on mine. Wife's is Carb, so I did the rejet myself. I would not change just the pipes. All the components are necessary for the fuel/air mixture to stay balanced.
The air cleaner and mufflers are pretty easy to do if you have a little mechanical skill, and some basic tools. After you're done, just take it and about $150.00 to the Harley Shop for the re-map.
Hope this helps.
Regards,
Bill
Hope this helps.
Regards,
Bill
Due to emmissions, stock Harleys are lean running....
If you enhance the flow (Air in, exhaust out), you change the efficiency. A remap puts it all back in place, usually with a performance gain. Intake and exhaust go hand in hand, and the computer makes it all happy if it knows the mods are there!
BRUCE
BRUCE
Yes, I agree with all above. You don't NEED the Stage I with the exhaust...but you will be VERY GLAD you did do it after it is done. It will give the bike a little more life...Remap is pretty much a requirement when you change these things otherwise the bike will not run well, so if you do them both at one time, you only have to pay to have the bike remapped once.
Mac
Mac
ORIGINAL: jtfrog
what is the download? Another name for remap?
I have an 04 Heritage and with just the pipes it ran a little hot. I just put the stage 1 kit on and a Dynojet Powercommander and did my own re-map. Very simple. I think it took me a total of about 1.5 hrs to do all the work taking my time. (I am no wrench either) It runs great and if I decide to change pipes or anything else that may require another re-map I can do it my self. My bike does run better since I added the stage 1 intake kit and re-mapped it
Matt
Matt
I have an 04 Heritage classic and had the screamin eagle stage one kit and vance aand hines long shot FSs installed and the dealer did it all for $960.00. I thought it was pretty cheap to get done right, it runs good and gets 42mpg and I have just under 1K miles on it and will take it in for the checkup on friday. To me it was worth it to get the dyno run and efi map done at the dealer for a no problem with the warranty issues deal.
