Kuryakyn electro-magnetic throttle lock
RE: Kuryakyn electro-magnetic throttle lock
ORIGINAL: grzly
I'll ask the question that I think the answer is obvious - does the system need the hand lever and grips for it to work . If so,are the hand levers chrome? secondly are the installation instructions good enough for dummies ?
tia grzly
tia grzly
To answer your questions you don't have to use the levers--your own will do but these are pretty sweet and they are chromed. You do need to use the Iso throttle grip--it has a plastic ring on it where the steel plate fits into--which is what the nagnet grabs to hold the throttle in place when activated. Something you need to know while you are looking for the clutch nuetral wire--at least on my '07 heritage the black wire with the tracer is on the clutch (left) side wireing harness along the frome under the seat. While you are checking with the test light--on my model the clutch switch registers hot to the positive side of the battery, not the negative side. Seems backward but the HD mechanic stated it took him a couple days to realize it was reversed from what he expected. The other two wires, brake and accessory, are tested with the light from the neutral side. Also the installation was a bit tedious, especially the cable ferrels on the throttle/idle cables but not very tough. The only "special" tools are a split ring pliers and a test light. If you have torx, screwdrivers, needle nose and other standard tools alls well. Good luck, once done very nice.
ORIGINAL: mikeshog
FWIW to others interested: M&M Cycles sells the kit for $144.00.
Gary
