Are these oils ok to use??
Guys,
Planning on having the oils done on my 06 Deuce. I have done some research on here and browsed around and think I know what I will use, I just wanted to run it past you all here.
06 Deuce, 2,600 miles
Crank
HD Syn 20w 50
Primary
HD Dino 20w 50
Do they still make the HD primary oil??
Trans
Mobil 1 75w 90
Crank
HD Syn 20w 50
Primary
HD Dino 20w 50
Trans
Mobil 1 75w 90
RE: Are these oils ok to use??
I use Mobile 1 for V-Twins 20-50W in the engine and the primary,and Mobile 1 75-90W in the tranny. Its all good stuff and easy to find, not to mention a bit cheaper than the HD Syn 3.
You can use HD's Syn 3 20-50W in all three holes if you like and itsOK, even recomendedby HD.
