i would like to get the easy pull clutch kit for my dad for xmas. his 97 fxstc clutch pull alot harder than mine. will this kit make it like the newer bikes? anyone install a kit? if so,what kit did you use?
thanks
Just had one put on our 96 wide glide for my wife. She was finding the clutch too hard to hold at stop lights etc. She reports it's a real big difference and is now no problem. Cheap too. $30 + install or something like that?
PS they routed the cables a little better and lubed them too...
I've had a Burly kit on my bike for about two years with zero problems. At first, it didn't feel as light as the '06-up H-D's did. However, after a few months of use, it got lighter and now feels pretty close (maybe even lighter) to the newer H-D clutches.
I must say, I put one on my wife's Nightster and it didn't make much if any difference. Lubing the cable helped a bit - more than the ez clutch, actually. Fortunately, as others have noted, it's a $34 part, and easily installed, so not much ventured, not much gained. YMMV.
Get her a Jockey kit so she can push that stiff **** clutch down wit' her foot?
Ha!
Buy the burly or something along those lines. They are $12.95 on E-Bay. Combine it with a HE or high efficiency teflon lined cable routed nicely. No need to lube the HE cable for a long time.
I had that setup on my Train with heavy SE clutch spring....Made riding around town veddy nice.
