If you install white walls on a '03 or newer HSC, you will be installing a narrower tire! They don't make white walls in the 150/80B16 tire size. You must sacrafice tread width - go with a smaller contact patch on the rear - to get the white wall. I'm all about the look, but not willing to sacrifice perfromance.
I have Metzeler 150 x 16 WWW on my 03 FLSTC.
Lyndall Z brake pads are the best, 2000 miles and no brake dust to clean off yet!
Just hose them down and go.
I don't think that is right ..... certainly it can be harder to get a replacement at short notice , but you can get the tire size
More importantly what do you think? thats what matters- keep in mind it wonlt be as "bright" as the photoshop andIMO they have probably made the white wall just a tad too wide....
