DiamondBack or Barnett cables??
If I wait until Dec15th, local HD stealer is having a 5-30% spin the wheel off discount on everything in house. So, I'm pretty sure I will be using stock cable length, so might be lucky if they got it in house for the discount. But, usually HD products are made for them, so I wonder how good are the cables compared to Barnett....
Here is another to look at compare to.
http://www.magnumshielding.com/
Thankx for the tip Gramps. I found a local shop that carries the Magnum and swears by them. I'm even gotting a discount. Going to take my cables so he can size them up.
BTW, I remember you saying you had some troubles with your hand control connectors, releasing the pins. See my post https://www.hdforums.com/m_2471180/tm.htm. Also check my new bars out: https://www.hdforums.com/m_2483427/tm.htm.
