Headlamp question?
RE: Headlamp question?
someone suggested this in another headlight thread. I'm thinking of trying it.
http://www.jcwhitney.com/autoparts/P...014812/c-10111
Go down to NAPA auto parts and buy a 100/80 watt bulb for about $10. That is the best bulb I have found, and I have bought them all. It really is brighter, instead of just making you think it is brighter by changing the color. I run this bulb in my softail and Vulcan both.
You need to be careful playing with some of the aftermarket high power bulbs.
Any bulb that draws more than about 75W is going to put a strain on the electrical wiring in the bike and has the potentual to warp plasticreflectors and connections inside the housing.
The best option is to replace the entire assembly with a nice new and longer housing from somebody like Headwinds but install a true HID system inside. Unfortunatly that's going to run you about $700 or more.
If your cheap, or poor like me the next best thing is either getting a PIAA H4 Intense white (about $50) or a Sylvania Silverstar H4 (about $20) replacement bulb for your headlight.
Neither of them will draw more than the stock bulb, preserving the electrical system and any plastics. Nor will they break your bank account. What they will do is significanty increase the output of the light over what the MoCo put in there at the factory.
Of the two I think the PIAA is supposed to bebetter, but is it is and how much better, I can't say. I have personally never seen one.
The Sylvania Silverstars on the other hand are supposed to last longer and I KNOW they are better than the junk the factory puts in.I have used them in my last three cars/trucks along withtwo different bikes and I have beenvery satisfied with their perfomance.
The odd part is that I'm not really sure that they are all that much "brighter", butthe color and quality of the light they produce allows even an old fart like me tosee better/farther/clearer then the stock bulbs.
Another plus is that they are very easy to find in most of the brand name auto parts stores. So finding/getting them or replacements when or if it should become necessary is fairly simple.
Good Luck and Ride Safe [sm=biker2.gif]
ORIGINAL: anubisss
Sylvania Siverstar H4st but get a couple as they tend to burn out kinda quick. It won't melt you bulb housing is the good thing. I got mine at Autozone.
I have heard that they burn out fast from other people too. But I have been using them in my truck and bikes for 6 or 7 years and have only had one burn out in that time. I put over 300,000 miles on the truck so it wasn't just a matter of time. I beat the snot out of that poor truck and it only had one bulb burn out.
I am making the same upgrades to my Fatboy for safety reasons. I would rather be seen coming than broadsided by a cager.
I am upgrading to higher quality H4 bulbs
Ordering the visipath headlight modulator for comagination with the 115w upgraded capacity, and also their Brake light modulator.
http://www.comagination.com/
These were reviewed by WebBikeWorld and seem to perform as advertised. Search for headlight modulators on the forum as there have been a couple threads. To follow are those that will say that they hate them cause they are annoying but that is what I want is to annoy cagers so they will avoid me. http://www.webbikeworld.com/Reviewed...h/visipath.htm
Good Luck, Stay Safe
