Exhaust Question
Exhaust Question
OK so I have had my fatty for nearly two weeks, first Harley and I love it.
Question - it came with V&H pipes, not sure what sort as I can not see them on the V&H web site, they are short and straight and slightly staggered. I have noticed that every now and then when I roll off the throttle the exhaust pops - is this normal?? Also have read a lot on here about changing air intakes and tuning fuel systems etc. As far as I know I have stock air intake (how can I check?) andstock fuel management system (also how can I check?)
Well you all probably figured out I don't know s**t about Harleys (other than how awesome they are!) Any advise on how I can check what I have got and whether I should be doing anything to make the fatty run better.
Thanks
Dave
[IMG]local://upfiles/47214/25E6858284504A408A1789600B2C419B.jpg[/IMG]
Thanks
Dave
RE: Exhaust Question
Welcome to the fatty world. The pic is very small, but I think you have the same as me, Big Shot Staggered. Chances are that the previous owner who put the V&H on, also changed out the air cleaner to a high flow one. Take of the AC cover and if it is a round cone, it could be a K&N, screaming eagle, big sucker or something along those lines, meaning a high flow AC. If it is oval, chances are it could be stock. Most people will change the AC if they change out the pipes. If you have the stock fuel management system, it will be hard to tell if all the previous owner only did a remap of the system. As far as the exhaust pops, its nothing to worry about, but you can purchase an after market fuel management system such as thunder max with auto tune, screaming eagle race tuner, or a V&H fuel management systemjust to name a few. I hope this helps a little. Rise safe and ride often.
Gunner, thanks for the info. I will check out the air filter (probably have to wait till the weekend). If I have stock fuel management system are there any issues with just leaving it as it is, at least for the time being?
By the way, nice bike - looks like your pipes are slanted at the end, mine are square. I will try and take some better pictures and put on - again have to wait till the weekend.
Thanks again
Dave
Thanks again
Dave
ORIGINAL: usdave1t
Thanks again
Dave
Thanks again
Dave
Another possibility for your pipes are short shots. Good luck.
Don't know if I got this right, but trying to give a bigger pic so you can see those pipes.
Couldn't get the pic to embed, so here is a link.......
http://picasaweb.google.com/usdave1t...79045824894514
That bigger pic is a help... it look to me that behind the oval AC cover that the rear black trim (about 1" thick) has been removed. That black trim is the edge of the stock AC so it does seem you have a high flow AC in there - brand is largely irrelevant they all do the same. Is it an EFI or carb model?
If it is an EFI model...
You haven't mentioned having being sold a little black cigarette size plastic box (which would be a SERT tuning module) so it is likely you've either got a Power Commander 3 (check under your seat and you'll immediately see it if it is there - it's a small plastic electronics box with PC3 all over it), OR, you have a V&H Fuelpak (virtually the same thng as a PC3 but made by V&H) OR, you have got a Stage 1 download (which you get from a HD dealer which reprograms the ECM (computer chip) to change the engine settings to acknowledge more air intake (due to the high flow filter) and more exhaust (due to the V&H BSS - nice pipes by the way).
The popping sound to a minor extent will intermittantly happen forever but the bike can be tuned to minimise this and virtually remove it. It sounds like for reasons unknown that the air-fuel ratio (AFR) is not quite right and the pop is excess air or fuel being pushed into the pipes after not being combusted properly. If you have a PC3 or Fuelpak you can endeavour to tune it yourself - there is alot of information in the engine area here online to assist, however if its a Stage 1 download you'll need to see a dealer for tuning.
If it's a carb unit... i have no idea.
FXSTD.AU, thanks for the info. I will be checking this out at the weekend. See what air intake I have and check under the seat for the tuning module. If it is a stage1 download I will get it checked out the next time I geta service. It is an EFI model. The popping is only once in a while which I guess is a good thing?
By the way - nice bike, love the pipes!
