Pic request: Night Train with 180
Trying to figure out what to do with my 02 Night Train. Not sure I want to spend the money on a 250 or larger conversion but I would like a little wider tire on the back. Figure it would be yet another winter project.
Anyone have a picture of a Night Train with the 180 Heartland kit?
Thanks
Thanks
RE: Pic request: Night Train with 180
with a duece rear rim(17x4.5) you can run a 160 under the stock fender w/o cutting the frame horns, anything wider and you will have to cut them. All you need for the rear wheel to fit is a 2in spacer on the left and some ground off of the calaper to center the wheel, i forget how much you need to grind off though
Here is my 05 with a 200 tire. I was able to use my stock swing arm, and brake caliper. The only thing that I needed was to change out to the skinny belt and pulley like on the newer bikes. Finally, I had to ditch the belt guard due to the change out.
Runs really good and gets lots of compliments. It really changes the bike and makes it looks custom.
[IMG]local://upfiles/21966/8F829CC9858746FF81B099718233462E.jpg[/IMG]
[IMG]local://upfiles/21966/C7554408BE7A41C78BF10C53044A3A94.jpg[/IMG]
Do a search for chops fat tire build. He did a200 withstock wide belt and caliper.A 160 Metzler will go under an 05Night Trainfender. This is mine. Check jimb's gallery he has a 180 under his.
[IMG]local://upfiles/2297/054F4C791CEC4AC28AC4E88204F3C398.jpg[/IMG]
[IMG]local://upfiles/2297/8FACB12609F644FBBAA98DB57CB0065F.jpg[/IMG]
DarrelRodman
10-28-2022 01:01 PM
