I was just given a set of Vance & Hines Long Shots that came of a 01 Fatboy, my question is can Iinstall them on a 07 Deluxe if I weld some O2 sensor ports on them and do they bolt right up.
you should be able to. I used a set of arlen ness of a 05 and put it on my 07 by welding bungs in the pipe for the 02 sensors. If you dont want to do that then you can get a fuel optimizer with 02 sensor eliminators and just put it on with out the 02 sensors.
Ditto... if your running a Power Commander you won't need the 02 sensors or bungs....... this would be the route I would go unless you already bought a Tmax.
