What kind of lift do you use for your Deluxe? I have the Red Craftsman which I bought used, but it does not slide under the bike. I need one which will accomodate a low frame height.
I have the same lift. Roll your bike up on two 1x6x18 pieces of lumber, one for the front tire, one for the rear.The lift will then roll right under no problem.
J&S, lifts the Deluxe with no problem, roll it under, and jack it up. 19 inches off the ground, moving the bike on the lift with NO straps, changing tires and wheels, still no straps...best jack out there.
