HD FAT MINI- APE HANDLEBARS
I was thinking of going with a set of HD'S Fat Mini-Ape bars on a 07 Heritage, I know the diam. isbigger than the standard bar like 1-1/4".
My question to anybody who knows, do the bars tapper down at the ends totake standard grips and bar mounted controls? Did not know if my old stuff& new standard grips would work on this bigger diam. bar.
Thanks,
Dan
Thanks,
Dan
RE: HD FAT MINI- APE HANDLEBARS
Dan,
I installed a set of these on my last bike. A Softail Standard. Yes, u do need the 1 1/4 inch risers. I went with the risers off of the 07 wide glide for my risers. They look really good I think. I did run the wiring thru the handlbars but I did not need to splice in any extension kit nor did I have to change any of the cables on the standard. I did have to bend the brake line a bit to lengthen it but that was it... just fyi. New cables would be preferrable though and would look alot nicer.
I do remember those risers being a bit costly... little over 100 if I recall.
Those bars look really nice though. If you are putting them on a Heritage u might not have to change any cables also as the heritage bars are around 8 or 8.5. Yes, they do step down to 1 inch for grips.
It seems like those bars were prett costly also... close to 300 maybe? I remembre buying them when my dealer had a 20% off sale and still spending alot.
You might want to check out Wild One chubbies. I put the 502's on my Heritage. They are 12.5 inch apes... but. I was able to use the stock risers and I did have to change cables. I went with the chromolites though and it sure does look alot nicer up front. I like the 502's cuz they are spaced wider. Are 1 1/4 cept for the step down for the risers and the grip areas. I ran all the wiring thru the bars and did have to use an extention kit for that. I think for the cable lengths I used 6 inches over stock.
I do believe the chubbies are cheaper than the harley mini apes also... but can't remember for sure.
I have been looking at the Chubby's for my springer, however several guys I have talked to said they would just stay with 1" bars cause the 1 1/4" are way heavier than the 1" bars. Anyone have any experince with this issue. Cause the bigger bars do look awesome. And Yes the Chubby's are cheaper than HD bars and you can use 1" risers since they step down at the riser as well as the grips.
ORIGINAL: jrspringer06
I'm very happy with my bars and am glad I went with the short apes. The quality is great and the comfort is top notch. I would ask someone who told that what exactly they mean by that.
A member here named Springer has apes on his fx springer if I remember correctly. He went from the HD mini apes to different, taller bars if I'm not mistaken. You might want inquire with him. He's a friendly and very helpful fella and I bet he'd be happy to help.
My preference would be 1 1/4 all the way around. But that market just isn't big enough yet to make it competitive.
Those are 9.5s on the bike in your avatar? I am leaning towards 12.5s.
EDIT: Never mind about the sizes... duh... maybe I need more coffee this morning... you have a Springer!
