FatBoy problems
RE: FatBoy problems
You are not helping us. What setup are you running. My estimate is that your carb needs a good clean up and i suspect that the seals must have worn out. My bet is that you are better of with a new carb (I have the new CV44mm - it runs great)
If money is the issue I would take off the carb use a carb spry to clean it up, change all the seals (especially the intake and manifold) then try again.
fatusboyus
03-09-2007 04:53 PM
